Cable stripper
Hi
I'm making my own cables. Just got some kit. Van Damme XKE cable which is soft covered. I got automatic cable strippers, those ones that look like pliers with a big complex head. I'm using them correctly, but they kind of pull and chew rather than making a clean cut.
Is it the cable, or did I go too cheap on the strippers?
Help please!
  • If you're working with various cable types and diameters then a simple snap-off type knife is the best.
    If working with lots of the same cable then the rotary style co-ax strippers are the best - set up the depths on some scrap cable first and they're ready forever.
    And a real good pair of small side cutters (Lindstrom, Knipex, CK - how much!! ) - buy good, buy once. Don't use them for snipping strings  ;-)
    The strippers you describe are best for elecrical cable.
  • jackiojackio Frets: 132
    @PrecisionGuided ;
    That's really helpful. And yes, a sharp knife works well. Doh! I bought a new toy thinking it would revolutionist cable stripping and lead making.
    But no, a sharp knife works well. I will have a look at rotary co-ax strippers too.
