Aging Jaguar Pickup Covers.
I have a DIY Bass VI (from USACG) - which means either buying Creamery or Novak pickups (I would love to) - or (being cheap) buying a Jaguar set second hand and buying an individual pickup .. which I did 2 x MIJ and a SD quarter-pounder for the bridge.
I bought a new pickup cover for the SD and following some very sagely advice made a cup of coffee and dunked the pickup covers in.
Observation:
The WD Music pickup cover has stained to a respectable yellow.
The MIJ pickup covers must be made from American tooth enamel and are as white as before.
I've ordered more WD covers and I hope the colouration has more to do with absorption properties of the plastic than strength of coffee.
  • PhilKingPhilKing Frets: 1481
    Mojo makes a set of Bass VI pickups in two styles (I think he still does anyway).  I used Bare Knuckle Jaguar pickups on mine, I mixed up a couple of different wind options for my set and they sound great.
  • tanihhiavlttanihhiavlt Frets: 659
    thanks I'll check em out. How is the bass vi working out for you? When it wsa different colours I tried it as a baritone tuned from A to A as well ... kinda prefer red that :) but then it had strat pickups in it as the USACG guitar originally comes that way.
  • FunkfingersFunkfingers Frets: 14465
    The proper plastic for USA pickup covers is slightly squishy with a glossy appearance.
    The MIJ/CIJ plastic is firm, inflexible and possesses an unbearable whiteness of being.
    The tinted plastic used for “aged” covers usually looks a bit fake.
    IMO, the best way to rapidly make white pickup covers look believably aged is to have a heavy smoker rub them with tar-stained fingers.
    I like it but have only used it at a gig one time, to play the Gin Blossom's Hey Jealousy, I wanted a low rhythm part as we needed to fill the song out a bit.  I really have to play it more.  I also put a Staytrem Bass VI bridge on it and use La Bella Bass VI strings on it, which really help stop the low E sounding flabby.
  • CasperCasterCasperCaster Frets: 762
    You need to use the dark Colron scratch repair stuff which comes in a little bottle (B&Q). It had an application brush in the lid. I got the tip from @WezV and it works a treat.
    Remove the covers. Use some very fine abrasive if you like to de-gloss them (i use 2000 grit, but you can start coarser and go to 2000 if you choose). This will also soften the corners slightly which looks more natural. Next daub on the stuff and you will immediately think you've ruined the covers! Leave it to dry for about 5mins then rub it off with a soft cloth.
    If the initial effect is too subtle then simply repeat.
    If the colour is too strong/uneven use a bit of white spirit on a pad/cloth to soften the effect. I found that if you are thorough then white spirit seems to remove 98‰ of it. If you want a really subtle effect apply the stuff, remove with white spirit, apply again, remove with white spirit etc. After a few cycles it does seem to slowly build up a little colour, and the white spirit loaded pad (which by now is dark brown) can also be used to apply a subtle coat.
    Once you've experimented a bit you can use a sponge, or a pad and can create areas which are deliberately more aged, and it will tend to stay within scratches and nicks if you want to go beyond ageing to relicing.
    I don't have a picture, but I aged a new Dimarzio pickup cover which was naturally a slightly different colour to the Fender pickup covers it needed to complement. I also added some wear and damage to fit the relic vibe of the instrument it was going on. @CountryDave now has that guitar and might be able to provide a picture by way of an example.
  • CountryDaveCountryDave Frets: 855
    edited June 2020
    @CasperCaster ;
    it looks a little darker than the other two pickups, but is bang on as that’s where my picking hand sits.
    I played an old Squier for about 25 years, gigging a lot. Over the years the pickups yellowed and discoloured and the one that went darkest was the bridge pickup - just where this one has.
