As an experiment I just tried to use Amplitube 4 in stand-alone mode and couldn't get it to work with my ASIO device, and just get a message "Could not initialize audio device". I might be able to help if you try it as a plug-in in Reaper, but I'm stumped with stand-alone mode.
It's an option when you install it. Looks like you only loaded the plugin.
No I've definitely got both the stand-alone and plug-in installed. I did some Googling and It would appear it's a known issue and there is a solution. But it's only of academic interest to me because I don't plan to use it in stand alone mode.
https://cgi.ikmultimedia.com/ikforum/viewtopic.php?f=5&t=12935&start=15
Here's a pic of what happens in stand-alone mode.
https://i.imgur.com/irDa6Ov.png
Are there interfaces that don't use asio4all and would this solve the problem?
https://www.steinberg.net/en/products/audio_interfaces/ur_series/models/ur12.html
https://www.steinberg.net/en/products/audio_interfaces/ur_series/models/ur22mkii.html
So is it the interface or the computer that dictates whether multiple applications can use the ASIO driver? I can run multiple applications with my current computer with a Zoom UAC-2 interface. But could only run one application at a time with my previous old computer with an Audiophile 2496 PCI interface.
https://www.ikmultimedia.com/faq/?id=1236
