So it is three years now since I took delivery of a custom ordered GSP Basses body and neck, I was very happy with the workmanship and how they came out. I am pleased to report that much progress has been made lately so I thought I'd start a build thread whilst the build is still actually in progress.
One day I would really like to design my own body & headstock shape but in the meantime the idea behind this build was to stick to the basic template of a Strat. I wanted a semi-hollow guitar, mainly as I really enjoy the interaction you get with an amp at lower volumes. I think a Strat with an f-hole works really well as long as there isn't a pickguard, those EJ Fenders don't look right to me. I went with a black korina back and koa top because, well just look at them! So I am expecting a comparatively fatter tone than most Strats due to the construction and woods.
The pickup configuration is HS- I would actually use the middle pickup a fair bit on a regular Strat but it does physically get in the way of my playing style so I've left it out on this guitar. I also wanted a fully floating bridge so I asked for it to be routed to allow pulling up on the trem. Also I had seen Graham’s very nice contoured neck heel on some of his other guitars so I went with that, he also installed the Grainger neck ferrules as I wanted to use threaded bolts to attach the neck as opposed to wood screws. Here’s the body before I received it (the masking tape denoting my request to move the 5-way switch as again I find the regular position gets in the way of my playing style):
And then me doing some sanding in the sunshine:
And here's the back- before:
And after!
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
It is getting a thin nitro finish on the front and then I am going to oil the back. One of the reasons I've gone with the gloss finish on the front is so I can use a waterslide decal for a logo, I got some from Rothko & Frost. And if the body is anything to go by it should really bring out the wood too! I do like the feel of an oiled back of neck, should work very well on the rosewood. I have a tin of the Crimson guitar finishing oil I was planning to use unless anybody else has any other recommendations?
Thanks! OK hardware wise I’ve gone for everything nickel plated, I wanted it to age with the finish. The last 10+ years I’ve spent playing two Ibanez (an RG and a 335 style) which, despite putting a lot of hours on them, both look pretty much as good as new which does leave you feeling a bit cheated!
So the bridge is the Floyd Rose non-fine tuner. The single locking trem is enjoying a bit of a resurgence recently- Guthrie’s got one on his guitar, so has Pete Thorn. I see it as a good compromise- you get to still use the regular tuners as there’s no locking nut but having the strings clamped at the bridge definitely aids tuning stability. I’ve also purchased a brass block, pop-in arm and some proper mounting studs- unbelievably these just get shipped with two wood screws to mount! I have a Tremol-No as well in case I break a string or want to change my tuning.
Machine heads I’ve gone for some Hipshot open-gear staggered post locking tuners with vintage buttons. And the pickups I have for it are a Bare Knuckle VHII and an Irish Tour.
The pics aren't great but the graduation between the gloss nitro finished headstock and oiled neck shaft has come out well too.
But I've availed of a few mods from aftermarket upgrades they offer..
First up are the two wood screws supplied to mount to the body. They're pretty chunky looking but I just don't like the idea of using wood screws to mount a floating trem. I didn't even like the idea of using wood screws to mount the neck, I'm using inserts and bolts- so I bought some proper inserts and studs for the bridge too.
Secondly I've gone for a brass block instead of what I'm guessing is a zinc alloy block. It is a good deal more substantial than the stock one as you can see here.
Thirdly I was very happy to see they offer a pop-in arm. Especially one where you can adjust the tension with an allen key rather than relying on, for example, the little plastic washers as with an Ibanez Edge.
Lastly I got some noiseless springs. Cos nobody likes squeaky springs. And they look pretty cool with the black finish.
Here's how it is looking now.
