Piano and synth/pad vst
I'm wanting to get back into recording and want to use my MAudio Oxygen 61. I'm going to use Reaper as my DAW. Can anyone Recommend a good either free or cheap piano and synth/pad vsti?
  • stratman3142stratman3142 Frets: 2201
    edited June 2020
    The free Kontakt 6 Player is an option. I'm a bit out of touch with the free Native Instruments stuff but I think Komplete Start might be where to start with that.
    https://www.native-instruments.com/en/products/komplete/bundles/komplete-start/
    It's not a competition.
  • lincolnbluelincolnblue Frets: 294
    Thanks. That does look like it could be a good option
    I've downloaded Kontakt and there's some keys sounds on there (as well as some great other sounds) but no standard piano. Anyone know of a good option?
  • duotoneduotone Frets: 994
    Haven’t tried them, but there’s a couple here might be worth a try.
    https://www.pluginboutique.com/search?qs=match&q=Piano&oses%5B%5D=&free=true
  • oafoaf Frets: 300
    Sampletekk(.com) have 80% off their instruments at the moment. Lots of good pianos. Think you'll need a full version of Kontakt though.
    edited June 2020
    The FluidR3 GM soundfont (link below) will give you the General Midi instruments including pianos.
    https://member.keymusician.com/Member/FluidR3_GM/index.html
    Then you'll need a free soundfont player such as sforzando.
    https://www.plogue.com/products/sforzando.html
    Btw. Kontakt 5 plays soundfonts but they appear to have dropped that feature from Kontakt 6.
    Years ago I used 4front upright piano
    http://www.yohng.com/software/piano.html
    If you don't mind paying then Truepianos is a good, reasonably inexpensive option
    https://www.truepianos.com
    Those are ones I use or have used. There are newer free versions if you Google 'free piano vst'
    The pianos I mostly use these days are Addictive Keys, or occasionally the NI pianos that come with Komplete Ultimate.
    Thanks all. I'll take a look. Sadly funds don't allow paying for the full version of Kontakt but I'll see how I go with these ones first.
    Try Spitfire Studios LAB collection. I use the electric piano but I think they have an acoustic one.
    Some of their stuff has atmospherics like big reverts added so you might want to work through them to see for yourself.
    Thanks - they have quite a lot of stuff on there which looks good - downloading now
  • midiman1962midiman1962 Frets: 102
    I've got into this scenario lately though i do use cubase.
    I also bought an M-Audio Oxygene which was bundled with a vst called Xpand!2 which i have been very impressed with.
    It might be worth seeing what came with yours?
    I am also using the Roland Cloud (Free version) which i would also highly recommend - somehow the sounds just "lift" above a normal vst.
    The other thing i've discovered is that it seems more economical to buy a midi controller with bundled synth than just to buy the software which took a while to get my head round.
    Arturia Minilab 2 being an example where you get the keyboard and analog Labs lite for £90 odd quid at Andertons
