So, I bought a GE7 so that I could mod, it worked fine when it arrived. Got the Monte Allums mods and did them myself, feeling very smug when I finished them and everything worked...cool!
Put it on the board and it was working fine...
Untill...
I was an idiot and took the back off to see if I could turn it over so that I could add pedal tape to it. Now the pedal when it has the back on, won't turn on. If I half put the back on, I can press a corner and it goes on and off. If I leave the back off, it's fine and keeps working, back on...nothing, so does this mean it's shorting somewhere? I've taken a video of the pedal to help
http://imgur.com/gallery/97FsW6fAny help is greatfully received
Check all that and then see what you got
1) insulator sheet is there and right way round
2) I made sure I cut all the legs after soldering
3) I'll double check the opamps as, I pushed them in as far as I could but you never know
4) jack sockets seem not to be the problem as they are solid
Its really seema to be a thing on the power pack and it's a really weird shorting issue when it's pushed
The fact it was working until disturbed makes me think something has moved so just take your time and go over it bit by bit
If still no joy make sure all the opamps have 9V between pin 8 and 4 and use pin 3 as a signall buzz in
Still need a new back for the pedal so it can go on the board like...
