One for the hive mind of tFB, please...
Next door has installed three air-con units - one for the kitchen, one for the lounge and one for a bedroom. Our neighbour (she is a recluse avoiding all contact whenever possible) doesn't like to open windows when it gets hot.
Two are on the far side of her house, and not an issue for us, but one is fitted on a hard wall, in a corner, over a patio. The sound it generates is annoying to the point we can't use much of our back garden when it's on.
Mid-afternoon, when it gets really hot, we have a shady spot at the end of our garden which is 15m away from that unit but the noise it makes is obtrusive enough that we cannot sit there at the time we need it the most. By late evening, she's moved to the other side of her house and turned it off.
Her son (who arranged for it to be fitted in the first place) doesn't live there, but was delegated to deal with us as we started complaining. She wouldn't even open the door to me! He's built a box to put it in. It didn't help much. He increased the amount of sound absorbing material. It did help, but not enough. Neither job was done by a sound-proofing specialist. Then, because we still could hear it, he called in the council to get their advice.
The upshot is the measurements the council chappie took aren't enough for it to be considered a statutory nuisance. Yes, we can hear it, but the legislation needs bigger numbers than he already has. He can advise next door further on what they might do, but he can't force them to do anything (he says).
So, I'd like to find out what else I can do if next door doesn't do anything else. The box could be improved (apparently) and the way it's fitted to the wall could be improved (apparently).
Apart from "Statutory Nuisance" is there any other category of nuisance I could explore?
Anyone had any experience of this sort of thing?
Ta.
Except play guitar at the same levels, as clearly all is fair in war.
https://twitter.com/spark240
Reddit r/newmusicreview
Speak to a specialist. But be aware it will not be cheap in the slightest. Nuisance disputes between neighbours are always disproportionately expensive.
Probably the cheapest way to get some views on whether the unit itself can be improved would be to ask professional AC supplier / fitter to give a quote for improving the sound deadening.
There is no such thing as sound proofing in these types of environments and consultants and M and E engineers who we deal with regularly go to great length to refer to Sound Reduction Systems specifically not loosely calling them "sound proofing ".
Whether they are cassette type units or have separate condensers the motors will be relatively noisy .Very expensive Daikin units are sometimes fitted with suppressors in Hotel environments etc but the reduction level is fairly negligible .
You cannot fix boxing with truly effective sound proofing quilting because the motors in the units will overheat .
Your best bet is to install some sound baffle screening but it's not pretty (unless you have instant climbing plants ) and is designed for House fencing where it borders motorways, train lines etc
Now it makes me wonder how pissed the residents were.. I know the outside of the building had several massive Mitsubishi units attached to the wall.. I imagine these are motors? I bet they made a racket come to think of it lol!!
Unfortunately, my neighbour is one of those people who never opens her windows and doors (no idea why, but it's up to her). So her house gets hot. She's chosen a solution that works for her but dumps noise onto us that she cannot hear. We choose to have the windows and doors open to let a cool breeze through and cultivated a garden spot that's really cool and (used to be) quiet. She had her unit running a couple of weeks ago when it was only 17C outside in mid afternoon.
TBH, I feel let down by the council. We didn't call them in, as we were trying to resolve things in a neighbourly fashion. Next door did, for "advice". Free consultancy, basically. Now they'll feel empowered to run it whenever they like. I guess the advice they wanted was "do what you like". Well, they got it. The council chap could hear the noise and understood why it was a nuisance to us, but the legislation isn't subjective, it's an objective measurement which has failed to protect us.
If what they are doing is legal then your actions won't be and they will be able to seek damages from you.
The frustrating thing about this is that she isn't going to be affected by anything I do because I'm naturally neighbourly and legal. She already blanks everyone else living around her (we're a sort of close/cul-de-sac that's been built like a small hamlet), never uses her garden, never opens the windows and doors and the houses are detached. So she just sits inside the house and the noisy part of her air-con setup doesn't disturb her in the slightest.
We're discussing coping strategies at the moment. I suspect all neighbourly cooperation from their side is about to stop.
We don't have her number and she often doesn't answer the door. I'm not sure what we can do if she uses it now, TBH. If the council can't stop her because it doesn't break the thresholds of the measurements in the legislation, then doesn't that make her entitled to use it whenever she likes? And therefore persistently asking her to turn it down constitutes harassment?
I don't know....
It will be a planning issue to do with the visual impediment of the location requiring consent.
It may be a Conservation Area with a section 4 notice which withdraws these things from being covered under permitted development .
Ive worked with Mediation Dorset in the past and they can be helpful but its not a guarentee
http://www.mediationdorset.co.uk/public/index.php
The problem with neighbour issues is that the law is often not on your side and even if it is you still have to live next door and maintain some sort of relationship with then after you have made complaints. To be honest it sounds like the son has recognised the problem and continuing to speak to him, especially if you can get him to come and have a listen and se it from your point of view, might be the best way forward. Also sounds like mum might have some issues of her own.
https://www.citizensadvice.org.uk/housing/problems-where-you-live/complaining-about-your-neighbour/
Allows each side to fully grasp the others in what should be a non-combative environment. If the mediator is any good anyway.
