Extending braided pickup wire...
if you don't have any spare braided wire could you solder a "normal" cloth wire to extend the +ve and solder another cloth wire to the outer braid to use as your ground wire extension?
  • ICBMICBM Frets: 72325
    Yes, although the extension won't be shielded. It won't matter much if it's fairly short - or you can wind the ground wire around the centre wire if you've got enough length of it.
