https://twitter.com/spark240
Reddit r/newmusicreview
The problem with people learning to mix on the internet, through YouTube videos and such, is they can be seduced by a series exotic techniques when in reality people are better off learning how to use filters (EQ), compressors and simple techniques to achieve musical balance to get productions sounding professional.
There is a laundry list of exotic techniques that people want to know about.
These include: Side-chain compression, Parallel compression, Brauerizing a mix, Pink noise mixing, Multi-band compression, Mastering whilst mixing, Using compressions as tonal devices, Fairchild compressors (usually plugins).
That is all good stuff and I use those techniques from time to time- but if you prioritise that stuff above and beyond the less sexy, but more useful techniques, like microphone positioning, understanding different compression types and how to use them, knowing the core frequencies of instruments, how to manage bass (especially in acoustically substandard rooms) then your productions are always going to sound unprofessional.
When I learned to play drums my teacher, Mike Glozier, was pushing me to stop 'majoring in minor things'- focus on the beat keeping and being on time, rather than overplaying, trying to use advanced techniques too soon. It is a great phrase and I've adopted it myself in a number of areas and mixing is very much one of those areas.
I'm not saying you shouldn't mess about with any of the above techniques but just give it the right amount of your time and attention- i.e. not a lot.
Concentrate on the stuff that actually matters.
FWIW I see it with a lot of guitar players too- they can shred the fingerboard but cannot play rhythm guitar in time.
I prefer doing a consolidation process where I get rough tones for each element as a submix (in a bus or folder), ie/ I'll use all 4 mic options to get guitar 1 sounding ok then treat that bus as a single track when it comes to balancing.
Plus doesnt pink noise mixing take ages for high track counts.
I've seen a video showing the principle of mixing to a sample of pink noise but all the hard work was already done in terms of EQ sculpturing and compression before the pink noise was used to set the fader levels .... and it's the EQ and compression that's actually the skill in mixing ... with a lot of subtle automation too obviously
I'd give that post a lot more than 1 wis if I could.
There's no harm with experimenting with different techniques for fun and interest but they aren't going to fix a poor mix if you haven't got a good graph of the basic - I do live rather than studio mixing but the basics of gain, eq and compression will sort so many issues if people bothered to practise those. imo hours spent practising using hpf and how to tame low mids will be a thousand times more useful than worrying about which compressor plugin - worry about that when you can hear the difference by changing ratio and threshold settings.
Same with guitar - you'll get more gigs being in tune, in time and knowing the song than worrying about the colour of your patch leads and how fast your sweep picking is.
I should ask say that I pretty fell into the trap of everything I am saying you shouldn't do- it is easy to do.
It wasn't until I started paying attention to the basics that my mixes started sounding as they should.
In the past though I've put up more mics because I'm not confident in my engineering, and especially working in an unfamiliar space with different monitoring, often monitoring through headphones in the same room etc under time pressure due to low budget, I wanted more options in case I fucked up.
Nowadays even though I think you end up with very slightly less mojo in the performance I tend to prefer to record a DI at home and then either reamp or just use plugins. I think I would need to spend *a lot* of time experimenting with mic placement and listening back to takes etc to get even close to the quality I can get in the box and at the level Im at the time.money is better spent elsewhere....like paying someone to time the drums which is the one thing that I will 100% be doing for our next project.
I subscribe to nail the mix so I've also got quite a few pro sessions and some of those have a lot of mics on each source, if you watch back the live mixes though often they already have an idea of what they want to use each mic for. I dont have the experience with different mics to be able to do that though...and if im brutally honest probably not the ears for it either.
I love my Kemper, but then the danger is that you end up procrastinating about which of the 2,000+ amps you use.
Life was so much simpler in the old days.
https://www.youtube.com/watch?v=_QkyzM0xLLk
https://www.youtube.com/watch?v=fGSTEBwxSbo
Daniel is brilliant.
Nice AWS he has too.
