Hi,
I've been working up to this for a while now, but I finally think I'm ready to take the plunge and do my own fret dressing. I've watched multiple how-to videos and I feel I've learned enough not to completely mess it up, plus I've recently put a new (second hand) neck on my tele which I don't mind too much if I screw it up entirely as I still have the old one as a back up.
What I'd like to know is what tools you think are absolutely essential, and which are more than I'll really need, given that I am unlikely to do this more than a handful of times in my lifetime. I'm currently thinking:
- decent fret crowning file
- fret levelling block
- fret rocker
- notched straightedge
- wire wool (0000)
Am I missing anything essential? I saw one guy saying to do it properly you also need to have a properly radiused sanding block after you've levelled - is that correct, or is that overkill for what I'm doing?
Also, I can get all of the above from crimson guitars - anyone have any views on their stuff?
Many thanks, in advance.
A sharpie pen to mark the frets, everyone uses black but red is much easier to see for me.
The radius block isn't needed, just follow the existing radius with the leveling beam, letting the beam do the work.
A fret end file would be a good idea to take any sharp burrs away after the crowning file action.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
To level, I use the Wudtone string-on beam. Sometimes with the strings off. Removes the need for a notched straight edge as it comes with 3 small metal blocks to check straightness, good enough. You can also use an aluminium spirit level if it has a machined edge.
For fret dressing, I can echo the points above. I have a mixture of tools from Crimson and Guitars and Woods. Crimson stuff is good quality but G&W is cheaper. G&W are in Portugal but shipping is faster than Crimson's.
At Crimson, polishing is all sandpaper of various grits then a buffing wheel (makes the frets shine like chrome!). At home I use sandpaper then 0000 wire wool then a dremel with a polishing wheel. Brasso works ok to, but wouldn't recommend it on a maple board as it can get messy.
