https://www.thefretboard.co.uk/discussion/185800/12-radius-bridge-with-9-5-neck#latest
Once you have the bass side raised a little higher than the treble the increase in string height should be nicely progressive across the board.
GE103B (Nashville): 12” (300mm) radius
GE104B (ABR1): 15.75” (400mm) radius
why on earth would they flatten the radius for the ABR1 type? And by doing so, making it incompatible with the majority of Gibson Type Guitars...?
[Imgur](https://i.imgur.com/IciQJfP.jpg?1)
[Imgur](https://i.imgur.com/zpUcaKB.jpg?1)
they also make it very, very difficult to flip the saddles (The bolts on the end are superglued).
The flatter radius makes it *more* compatible, not less.
I agree with what you say about the saddles though, that was nearly a deal breaker.
So the bridge can be fitted either way round and still give the right saddle stagger. All far-east tune-o-matics seem to be made like that.
Although I usually find that the D is wrong, at least - sometimes the A as well. On the typical Korean ones the first thing I do when setting up the guitar is turn the saddles round so the front face is vertical and the ramp is on the tailpiece side - that also helps reduce string breakage.
The scale length on the D string is shorter than the G, so I would expect that they either
a. provide easily flippable saddles (the Gotoh's are super-glued), or
b. keep saddles such that
1, 2 & 4 flat face towards pickups
3, 5 & 6 ramp towards pickups
(Like me!)
