EDIT: Title amended to reflect it's actually a single coil-sized humbucker that I want.
I have a WTB post up for an older version Seymour Duncan Little '59, however, I'm not sure how successful I'll be
https://www.thefretboard.co.uk/discussion/186923/wtb-seymour-duncan-little-59-for-strat-bridge-in-white-older-version#latestSo, I just wondered if people had any personal recommendations for Strat, single spaced, stacked humbuckers in the bridge position?
I'm aware of some of the other Seymour Duncan ones (JB Jr, Screamin' Demon etc) and I'm not a fan of the newer Little 59's but these other ones are a little hot and I want keep medum output and note the Little '59 is a Ceramic rather than an Alnico.
There's also the Dimarzio Injector that Paul Gilbert uses and the Dimarzio Cruiser, but any recommendations or experiences with any of these or others?
Thanks
The STK-10 YJM Fury does but, in the bridge position, it produces the tones of a slightly beefed up Stratocaster.
Of the Duncan side-by-side coil pickups, the only models with an Alnico bar magnet are the Custom Shop Pearly Gates For Stratocaster and its more affordable derivative, the Red Devil.
I've recently put some dimarzio rails in my strat and they are very good although the billy Corgan ones are a bit hot and dark.
I don't think the Cool Rails is intended to have a humbucker-like sound, though.
First thing that came to mind for me was the DiMarzio Pro Track, that's designed to sound like a vintage PAF in single-coil size, so a similar concept to the Little '59. I've never heard one directly compared to the other, though.
However, DiMarzio have loads of newer side-by-side Strat humbuckers, there might be something there which would suit you better.
I should own up that I'm generally not a fan of SD pickups and I usually end up replacing them or selling the guitar.
I detest the Li'l '59... but like the Li'l Screamin' Demon and the JB Jr. - the LSD is in fact only medium output, despite its name. I'm not really a fan of the Rails series, although the Hot Rails does have its place as the highest-output passive Strat pickup I know of. The Vintage Rails is terrible.
I also like the DiMarzio Fast Track and Chopper.
None of them sound like the full-size pickups they're claimed to emulate though - it's impossible due to the restrictions of the coil dimensions and the sensing length on the string.
I actually put a full-sized 59 in a Schecter Custom Shop Superstrat and was disappointed they didn't even sound in the same ball park. However, I have a full-sized 59 in the neck position of a Charvel I've just acquired and I really like it with cleans and overdrive.
I'm also not a fan of the newer, full plastic-cased Little '59. It sounds harsh and shrill to me and I have heard the Li'l Screamin Demon is meant to be tamer than people think.
Let's see as there may be an old, Little '59 on the horizon, courtesy of these fair parish, but if not it'll be a bit of journey but Seymour Duncan outlets still seem to have a 21 day returns policy.
Much appreciated
I was looking at that as they had it up against the JB Jr and there were some other clips - Cheers Steve
I wanted the latter and tried a Bare Knuckle Sinner (with backplate) Neck pickup at the bridge...sorted!
I have a Duncan hot rail-I think, in another, which is a bit too brutal sounding. And I think my favourite is a Dimarzio Tonezone, in an esquire, that pickup is a bit special, and is perfect for my needs.
I'd think having one in a strat might have some unintended consequences in positions 2 and 4, and it might be difficult to get a balance with the other pickups. The Dave Murrey and Ed O'Brian strats may give some insight.
My music:- https://soundcloud.com/hubobulous
