http://www.rabswoodguitars.co.uk/
https://www.facebook.com/RabsWoodGuitars/
My Youtube page
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
My Youtube page
Be aware of your final dimensions. If your top needs to be 25mm at the centre, your wedge will need to be thicker than that... Probably 25mm thick at a point 50mm from the join
Instagram
Some clues there
edit, although it should be noted that the wedge method used there is for getting perfectly quartered spruce... not a perfect bookmatch.
for a perfect bookmatch i would just cut it normally at 25mm thick, and plane the slope into it by running through the thicknesser shimmed up on the thin edge, leave the center section flat at the thickness requested.... it feels like a wasteful way of cutting wood either way. That's the nature of a carved plate and usually reflected in the price
I asked for some wood for a small archtop recently. The guy asked if i wanted wedges and i said yes. TBh i wasn't that bothered for the size, and should have made it clearer. We ended up going with a flat set after he killed a nice billet trying to figure out the best way to do it
let us know how you get on, as i could really do with a couple of other back/side archtop sets at some point
Instagram
Sorry I didn't mean for you to buy from him, but give him a call and he tell you how he does it, he's a very helpful guy. I'm going out there later today, if he's cutting wedges I'll take a photo of him cutting them, I do know it is done on a bandsaw.
Ideally you'll want a lip at the back edge to stop it slipping backwards as it goes through the planer. Depending on the overall width you might want a second piece underneath as the thicknesser rollers can distort it a little if unsupported over wide pieces.
Another option is to cut some wedges on the table saw and pin these to the MDF board so the timber panel has more support across the whole width.
Planer sleds are really satisfying as you get a nice shaped piece coming out the other end!
here is a quick sketch on how i think it would need to be sawn from a billet for minimal wastage. I'm not saying the cuts are easy
https://imgur.com/YQmwh47
Left is a rough idea of the cuts from a larger billet in order. Right is making sure the bookmatched face is on the right surface
Instagram
The billets of spruce used for tops are already wedge shaped, split from the log rather than sawn. its then a case of truing that up and splitting it down the middle... as shown in the link i posted earlier (actually, that is is maple)
I'm honestly not sure how they normally do it from bigger billets and planks, but i would doubt most commercial ventures accept the extra effort and waste of planing when they could just sell them at a consistent thickness instead
edit: for context, the rough sawn spruce wedges i have here are roughly 1 3/4" thick at one edge, and 1/2" at the other... you can see why wastage would be a concern if cut from a rectangular blank
Instagram
Yeah my boss said just to stick it through the bandsaw, and while I am okish at it, I cant see it coming out that well.. When ever I do a straight bookmatched top through the bandsaw I have to allow at least 5mm of re-thicknessing to get them flat again.
Wastage is something we just have to do sometimes to get the piece that the customer wants.. They pay for the full thickness board though so its up to the customer.
Ok, some reading up to do before I attempt this. But I will post my results when I do it
My Youtube page
My Youtube page
BUT if they like it and want more I will need an economical and reliable way of doing this or it wont be worth our while when they ask for 50 or 100 sets which is why doing it manually with a hand plane is out.
My Youtube page
My Youtube page
Make a sled for the bandsaw and then another for the thicknesser
Neither sounds like a fully carved plate, and neither can be carved as gracefully
Instagram
My Youtube page
