Probably the easiest solution is to cut the cable at the pedal and fit a TRS plug and socket so you can still use it separately if you want, and mount a small two-button switch on the pedalboard as well. I would use a right-angle plug on the cable so it doesn't stick out too far if you're using the original footswitch...
Just curious really!
(Apologies for any thread derailment but I thought it’d be ok given the original question seems to have been answered)
The reverb footswitch operates on the return of the tank, whereas the reverb control operates after the return amplifier stage; likewise the tremolo footswitch operates on the oscillator, but the intensity control operates on the link to the bias circuit. Thus in both cases, it's possible that turning the control to zero will result in less background noise than switching off with the footswitch - but it won't be a big difference since they're not very noisy anyway.
