Hi. I am in the process of building from scratch a 67 Flying V, a first time for me and I think I have made an error in my choice of humbuckers. Not being sure about the string spacing I bought a set of Seymour Duncan vintage blues humbuckers which are 49mm string spacing. I intend to put on a Nashville T.O.M. bridge and vibrola trem. These I believe have a string spacing of about 51mm, (might be wrong here) hence my issue. So will these humbuckers be ok or what are the correct type for this model. Are there any alternative make of pickup that will do. Thanks
Play a Strat on the neck pickup, bend a string up to directly in between two of the poles, and see how much the signal level drops. It makes slightly more difference at the ends of the pickup, but still not a lot.
You may find the string tone will be different whether you pick up or down too, puling the string over the pole or away from the pole.
But it might not be a problem for you when playing in the moment so I would fit them and if you find the volume drops off too much on misaligned poles then replace them.
