I would still run them in parallel though, unless there's a pressing reason you need to control them both from the first amp. It will give you a cleaner signal to the second amp and no possibility of overdriving it before it reaches its full headroom.
I read up on the ADA cabs and it appears they're fitted with Celestion G12S-50s... these are not an efficient speaker, and if you just want more volume you'd probably do at least as well to replace them with something more sensitive.
