Pot values
I’m planning on matching an Oil City Wapping Warf (bridge) with a Mojo Staple p90 (neck). The bridge will be tapped on a push pull tone pot. I’m inclined to go 250k on both would that seem a sensible approach? Just a bit concerned the p90 may be a little on the dark side...
  • ICBMICBM Frets: 72444
    I would go with 500K pots, and if the bridge pickup is then too shrill when tapped, use the second side of the switch to add a 470K resistor in parallel and simulate a 250K volume pot.
  • Okay thanks, I’ll give that a blast!
