If you are monitroing through a physical amp etc then turn off record monitoring on the track in reaper and leave it on in the interface.
Also sounds like you might have a high latency so try adjusting the ASIO settings to a lower buffer size.
However, all I am doing at present is plugging the guitar direct into the interface and playing minus effects. I add Reaper effects afterwards. My hope is to use my Pod 2.0 or record via a mic'd up amp as I progress, but I think I need to sort my settings first!
Where would I find the ASIO settings and what's the optimum buffer size?
I have an AKAI midi keyboard and have assigned some simple sounds to the pads in order to play along to my guitar line, but there is a lag. I can tap along in time to music quite well, but using the pads is out of time - is there another setting I can alter?
I don't know much about MIDI, but I don't seem to have the same issue making beats in AKAI Beats software.
