amp/combo handles
HootsmonHootsmon Frets: 15962
anybuddy ever done a DIY on their single leather strap handle combo and added side handles or recessed Marshall type handles,yeah....pics?
tae be or not tae be
  • Modulus_AmpsModulus_Amps Frets: 2580
    yes its easy, What amp is it that you plan to modify though?
  • HootsmonHootsmon Frets: 15962
    edited September 2020
    boogie express 5:50 (54lbs)
    I like the thought of the Marshall types as i guess they would be less likely to hurt hands
    @modulus_amps
    Hootsmon said:
    modulus_amps
    Not fitted them in that amp, check the clearances around the speaker.
    If you have a jig saw and a router it is pretty easy to cut out the side of a cabinet,  make a template first and use that to ensure you don't damage the tolex.
  • ICBMICBM Frets: 72345
    I would try to find the correct Mesa lift-up type handles and not Marshall-type recessed ones, which also avoids that problem. Not that it *really* matters, I just prefer to do things 'like factory' if at all possible.
    Like these...
    That's good John ^ is that factory fitted i wonder?
    Yes sir
    Guess I would need to get my cover altered....
    I am not 20 anymore and i don't trust my hips with the Express 5:50
    Hootsmon said:
    Pretty close - it's got slightly fewer screw holes, but if it's not lifting a Trem-o-verb that probably doesn't matter :).
    Did i read in these here pages that you were a fan of the tremoverb John?
    lol
    Until I got fed up of moving it, yes. Even then I might have kept it, but I had some medical advice I thought I'd better heed.
    Hootsmon said:
    This looks closer John...... but the silver!
    I would go with the black - no-one will notice the wrong number of screws, especially as the amp is smaller than a Trem-o-verb.
