Looking for some help as to what might be causing a sync issue that seems to be occurring when I record some tracks into Garageband. My band recorded a track in the studio a few weeks back, but I wanted to add some more parts.
Guitar > HX Stomp > iPad Pro > Garageband. I've got the track tempo set correctly. Once recorded, I'm exporting as uncompressed WAV and uploading to my G:Drive.
When this is downloaded and imported into the track file in the studio, I'm being told that it's all out of sync, and won't fit at all. I have not been present at the studio to hear what exactly is happening unfortunately
Earlier in the year, we recorded a track at the same studio but I had to miss the whole session. I recorded all of my guitar parts in the same way, uploaded to same location and everything was totally fine.
Has anyone had any similar issues, or knows how to resolve this?
What did they send you for you to play along with when tracking your own parts? Did you import that into GB on the iPad?
If you listen to the WAV file you made (outside of GarageBand - with something else) is it at the right tempo and pitch?
I tried two methods:
Playing along with the recorded track with no click/drum track playing in GB
Then, I added a pre-programmed drum track in GB at the correct tempo and played along with this, so the timing should be bang on
None of the tracks seem to be in time when imported to the Logic file.
All of the WAV files sound fine when listening to them on another source.
As I say, I sent a full track's worth of files that were recorded the exact same way, for a different session back in January, and every track was perfect
If you want me to take a look and can make the session available to me I can probably figure it out.
I don’t have access to the studio session I’m afraid, only my GB file. Is that what you’d need, or both?
I'd need both to fully investigate.
The studio engineer has managed to get some of the riffs sorted out, but apparently it took him a bit of time
That might be the issue- can you check what sample rate the HX Stomp operates on?
no DAW knows where in a song your solo should be unless you give it a starting point...
let’s say you have a song that’s 3 mins long and you record a 30 second long solo 1minute 15seconds into the song... you have to bounce the solo track from the start of the song... you will end up with a track that has 1min15secs of silence then a 30 second solo... this will line up properly in your project.
if you just bounce the 30second solo and then import it into your project it will automatically line up with the start (or wherever you place it) and it won’t be in the correct place within the tune.
does that make sense?
it seems as someone I think already mentioned above that GarageBand is limited to 44.1 where most audio now is recorded in 48k. Video in Europe is popularly filmed in 24fps and I think this is somehow related , and looks like it could be in your case .
anyway I then found out that you can get GarageBand free on trial for 90 days so I am going to download it and have a crack at using that. I’ve been watching some introductory videos and it seems pretty cool, plus if you want to send stems to people to mix or master it is more likely to be simpler in logic and more people are equipped to Deal with them.
I am such a noob to this but like I said this seems to tie in with what I have recently been researching on various websites
@smudge_lad If you're able to explain how you were supplied the original files that you have been playing along to, and in what format they are, I think I'll either be able to explain how to import it to your GB on iPadOS and turn it into a project or explain why it can't be done. If you wanted to share them (DropBox, whatever) then I'd be happy to have a go at doing it for you and sharing the project back. I can take it as a Logic Pro project or as individual files. Also just curious what version of iPadOS you're running and what your iPad model is - some older ones aren't getting the latest updates any more. The AudioMIDI setup suggestions only apply to macOS, not iPadOS, BTW.
None of what you're trying to do should be a problem - I've been doing this myself over recent weeks and it's working fine for me. We just need to find out what I'm doing that is different to you.
The file I used to play along was an MP3 file uploaded into Dropbox. I played that through my phone/speaker, and played along/recorded into the ipad.
put it on its own track in garage band...
record your guitar parts onto a second track...
Solo the guitar track and bounce as a wav but make sure you have cycle on and it covers the full length of the mp3.
you should then be able to import the bounced guitar track into any daw and it will line up with the rest of the tracks!...
We’ve just done this with a bunch of us that have never met or been in the same room... all using different daws and files sent via file transfer.
https://www.thefretboard.co.uk/discussion/191247/a-fretboard-collaboration-dirty-snake-mouth#latest
it should work fella!...
Although there can be sync issues drift caused by clock errors in circuits this generally only happens when lining up video / audio recorded on the cheapest shitty video camera's .... even the most basic audio clock on a laptop or iPad won't drift noticeably over a 4 min song
https://midnightmusic.com.au/2016/10/how-to-import-audio-files-into-garageband-for-ipad/
iTunes
Feedback
