If you really want to go down the smart route though a quick google turned up at least one system that says it replaces all the heads on the popular makes.
https://www.heatingcontrolsonline.co.uk/radiator-valves-c-28.html/replacement-trv-heads-c-28_51.html
I sent them pics of my old one to confirm that the new one would fit as my old one looked a bit different (older model I guess) and they were pretty helpful
1. Many CH systems are run far too hot (flow temp at close to max). This causes valve to heat up and "close" way before the room reaches correct temp. End result, everyone simply cranks them wide open to get radiator hot again.
2. Valves placed in sub optimal location I e vertically on incoming flow. The best location is horizontally on Flow & with pipes connected TOBE ie Flow at top of rad, return on bottom.
3. UK habit of turning on heating for short bursts "full blast" rather than longer time at lower temperatures. Poorly insulated homes drive this behaviour.
So you end up with all TRVs set to max, doing diddly squat.
Feedback
