SOLD Push-pull pots - 500k audio taper
goldtopgoldtop Frets: 6160
edited December 2020 in Parts £
I've got 5 of these. New old stock, never used nor soldered.
Yours for £10 each + £2 postage. Proceeds to the forum.
  • kipplekipple Frets: 354
    I will take one please PM me details for payment
    I put peoples heads in horse's beds
  • goldtopgoldtop Frets: 6160
    Easiest way to do this is:
    1. Make your donation to the forum's PP account: admin@thefretboard.co.uk
    2. Take a screenshot of the successful transaction
    3. PM me with the screenshot and your delivery address
    4. I'll post it out within a couple of days
    One gone. 4 left.
    Bump!
    Black Friday bump: £10 for two! BOGOF!
  • PM’d for two.
  • timbuk02timbuk02 Frets: 271
    Any chance you know if these would these fit Yamaha SA without having to drill the holes bigger? If yes I would like two too...
    OK - will have to check the threaded part's diameter on Monday, so the last pair have your name on until we find out otherwise. Of course, you'll have to check your guitar unless someone else here knows?
    thank @goldtop I'd read the holes are smaller than standard/modern 335. Hopefully some wider forum wisdom will intervene...
    From looking at the photos, you can see that the threaded part is not much thicker than the shaft for the knob. Knob shafts are typically 6 - 6.35mm, so I'd guess these are approx 8mm.
    Just thought - perhaps the obvious thing to do is that I just send them to you, you can check them directly and if they fit, then make the forum donation payment? PM me if that works for you.
    Bumping to say that ignore the above - there's still one pair left at £10 for the pair.
    NOW ALL GONE
