Bright Onion Passive AB Switch Pedal, £10 Delivered. Simple solution for general purpose switching, ideal for Eric Johnson type setups as its passive and has a DPDT switch. Velcro on the bottom which is removable.
SOLD D'Addario Planet Waves NS Micro Tuner, £6.50 each delivered.
SOLD Modified Gibson Historic CTS Pots x 2, £5 delivered. Readings are both slightly over 500k and both work. I wiped off the internal lubricant to make them quicker.
SOLD Adhesive Velcro, £3 delivered. For pedalboard, 1m of hook, 3.5m of loop. Width is 5cm.
SOLD Plectrums, £3 for all. Most are heavier if you wanted to give that a go: Big Stubby: 2.0mm, 3.0mm, 3.0mm (Teardrop) 3.0mm (Nylon) Jazz III: Original, Ultex, XL, Dunlop Primetone: 3.0mm Classic Large and Sharp Tip, Herco '66 Nylon Reissue: Extra Light, Medium, Heavy
SOLD iRig , £3 delivered. I used it for GarageBand on the iPad, best to check if it will work on yours first.
Usual PayPal thing, pop me a message and I'll get them sent out.
Please let me know if the D'Addario tuners do not sell.
Many thanks
