SOLD Hot Rod Pickups T90 Bridge pickup
Evening
Next trinket up on the block is this raunchy beast of a T90 pickup from Eternal Guitars/Hot Rod Pickups
https://i.imgur.com/gLxggIQ.jpgManufacturers specs here
https://www.eternal-guitars.com/hot-rod-pickupsIt’s a lively one, checking the specs this bridge unit is wound to 13.5k. I’ve not got the best ears so not really sure quite how good a job it does of replicating a P90, it’s definitely got more shunt than a classic Tele bridge pickup,it was previously in a mahogany bodied Telemaster and it sounds incredible pushing the front end of my Budda, absolutely brilliant crunchy rhythm tone. That said it does clean up pretty well on the volume pot too
https://i.imgur.com/iCkawMT.jpghttps://i.imgur.com/Eth5iLt.jpgThe yellow wire has been spliced but the black hasn’t and there’s enough on them to reach a standard Tele control plate
These are £80 new so £40 ?
As for trades ? I’m after a set of Hipshot Griplok Open Staggered tuners for a Strat so if you’ve got a set of those that could work. Would probably go Sperzels as well ?
