There's probably a much more technical reason for it...
https://twitter.com/spark240
Reddit r/newmusicreview
dBFS == decibel full-scale and is what all of our digital meters tend to show levels in, which is roughly equivalent to 0dBVU, which is what an analog console would show you.
If you aim for this signal range, you'll be giving yourself plenty of headroom and the rest of your plugin chain will react nicely to this sort of input level, and you've still got the flexibility to boost it later on if you need to.
In short - don't record too hot! There's no point!
The pad is normally 2 series resistors in line with the hot and cold and then one resistor after joins the 2 ... called a U Pad. As it's basically a voltage divider it won' add much in the way of noise
