Turn it up! Screw polite TV volumes ffs!
My sound veers between brittle (cleans or just breaking up) and mud (overdriven).
Whatever guitar I seem to use. Hence I have been trying to rethink for a home use tube amp that works at low volume. Did wonder if Jamie’s Laney 15r would be an option, but still not sure.
Usually end up blaming myself though. All the demos of my Vox AV15 sound great, so why can’t I ??!!
Much better at rehearsals - which is encouraging.
This is where I recommend my extremely rare pedals and the king of tone circuit works well but so does the Friedman BE and the Rockett Dude. The Fuzz Factory is great with a clean amp but probably too crazy.
I've found my Kemper into FRFR or Line 6 Powercab (only recently tried one) sound much better than any amp at home/TV volume quiet levels.
As for when everything is turned up to stage volume, thats a different question. But I've hapily switched to Kemper for home use, as I was just getting frustrated at trying to get expensive amps to sound good at home.
Have you tried reducing the amp presence/treble and rolling off the guitar tone pot?
Maybe try something like a Tubescreamer for overdrive (or Boo instruments TS808 clone) these do not colour the EQ very much and work well for me at home.
An attenuator would also help you hear some of your valve amps natural power amp distortion that you won't be getting if you have the master volume really low.
Feedback
Playing at slightly higher volume I've had some luck stacking OD pedals. Boosting an amp-in-a-box pedal set at low drive with a Soul Food for some reason gave me a much livelier sound than with just one pedal set at medium drive.
Depending on the amp, having the master as high up as possible and the preamp low may also work - I guess I could just have quoted @Alexlotl 's post above as he's basically saying the same thing.
Practically, this lock down, I found the hassle of getting amps, cables and pedal boards unpacked in order to have frequent requests to "turn it down" in a crowded loaded down house to be a complete pain. I really like the Katana Air I have but I only use it clean and even that is said to be too loud!
That all means most playing is done sans amp... or silently recording and listening to playback on headphones.
