I was watching an old YouTube video & know you love your modellers & wondered what IR’s you are using? Still the ones from tone junkie?
I like the free Redwirez greenback IRs. There's one particular one called M160-CapEdge-3in (or maybe 2in, can't remember!) which sounds really good to me.
I also have the Celestion Creamback pack, but it is drier sounding than the Ownhammers, although possibly more authentic.
I tend to load in a handful of each option - recently I've been starting with the um70 position 3, and i'll switch to 1 or 2 or 4 or 5 to get the frequency balance I'm looking for in conjunction with amp settings as I'm dialing it in.
When the um70 is too bold in the mids, I switch to the 57 which is "flatter" not in the sense of frequency response but in that it sounds more compressed, grittier, smaller and boxed in - whereas the um70 has a great midrange thing where it sounds like it's coming out the speakers a bit.
And the 121 is just there if I like the sound but want to dial in a second IR with more bottom end.
That's my starting point for pretty much everything, from clean AC30s to boosted SLOs. In real life I really like celestion alnicos, but IRs don't break up, thicken up and compress the way the real things do. I do like the Ownhammer vox 2x12 with silvers, but tend to use it when I'm placing a guitar part in a production that's already full and I want a sound that "tucks its feet in" and slots into its own midrange space.
The equivalent greenback options from the Bogner 2x12 pack are decent too, and I use them sometimes but mostly when I want to differentiate a double track etc.
Bandcamp
Spotify, Apple et al
Bandcamp
At the moment I'm using them with my Friedman PT20 and Suhr reactive load box IR. I'm using the Celestion Creamback 65 4x12 (Royer 121 & SM57 mix) with this setup exclusively and it sounds fantastic.
On a side note how are you finding the Axe III? I'm seriously considering moving to an FM3. Is the quality of the III a big jump from the AX8? How does it compare to the Kemper? How is the feel and the sound quality of the III?
The fractal cab thing is a bit of a different way of doing things but already includes a boatload of IRs from third parties, so I'd suggest buying more might just be adding more choices when you've already got 3k+ to choose from?
Am a Helix user myself, and your quite right about the stock cabs. It’s something I should definitely experiment with more. My template is I just go for a 4x12 as it seems to have a more open sound to my ears.
But, TBH, I find it's all a bit of a rabbit hole. Most IRs can sound absolutely fine if you spend a bit of time with the EQ and mic placement (if there is software that lets you do that) and the massive choice available just results in more browsing and less playing.
For example, I've created a 'main' preset with 8 Marshall amps in it, and different IR combinations for each, all selectable via the FC12.
The sounds are superb at bedroom level, and I'm pretty sure they will be awesome through my two RedSound cabs as well. Feel wise, it seems to be on a par with the Kemper, and the responsiveness seems to be there as well - which is excellent.
Thanks all for the input!
So after watching a few Leon Todd videos I decided to go against my stance of not buying more and started to peruse the York Audio store. They were inexpensive so took a plunge on the Hiwatt with Fanes and thoroughly enjoyed them. I did so because not many IR makers have the Hiwatt/Fane combo, let alone any that are worthwhile or worth my money.
Consequently I bought the new Mesa and Marshall T75 sets and they're superb for my needs. I've not needed to make cuts and they seem to sound full and rich. The only issue I can see is that there's no Marshall cab with V30's on his store, but I'll be eager to try his Greenback Marshall cab and the Friedman loaded with V30's. If the packs I've bought are anything to go by, I think I'll be impressed.
Oh, and I was impressed by his approach to it all and the simplicity of the packs and IRs. He's got a good manual for each of them and they're intuitive to use. He recommends a good method of trialling them in the Axe FX III too.
What are you using now @FarleyUK?
High gain, 57+491 combos.
Closed 4*12 for Marshall style amps.
For other amps, mostly open back 2*12, IRC.
OH 412 MRBW MED SP2-05
The BOLD-M+ is there because I wanted a mid heavy IR with our previous band lineup. I’m currently re-working my amp sound for the new lineup and repertoire, and might pull the mids back a bit.
