How do you know that the room climate is the actual cause?
If you haven't already, I would get an accurate humidity meter and find out what the actual environmental conditions are.
If there is too little humidity (as it sounds like) then get a humidifier, too much humidity get a dehumidifier.
Are there wide temperature fluctuations in the room where the guitar is kept? That could cause issues too, in combination with the humidity levels.
I don't think you need to look for another reason, as widely varying temperatures, probably in a short space of time, will do what you describe alright.
I'd be keeping them in the house & taking them out as & when you want to play them in the office, then take them indoors again.
All you need is a hygrostat and a humidifier
A garden room is a harder problem though, temperature will vary massively, and humidity too
Basically, on a cold dry day, when you heat up the room, the relative humidity of the air coming from outside drops massively in the room.
If it's 50% RH and 0C outside, at 22C inside RH will be 12.7%
Relative humidity calculator (lenntech.com)
In a house, washing, cooking, bathing, living/breathing will mitigate this somewhat, far less so in an external garden room
Do you have any idea of the min/max temperatures in the room?
btw I would not store any guitars in a garden room, even in their cases, unless it was heated every day, well insulated, humidified, and protected from temperatures over 30C in the summer
did it stay there on hot days, or did you stay away from it for a few days ?
I'm guessing you need to make a decision whether to heat and humidify it all the time.
From experience, I'd say when it's frosty outside, you'll get down to 25% RH or below
I'd avoid the ultrasonics, they get pink mould in them
I use a hygrostat mains socket attachment with a heater-based humidifier that is "dumb" and just switches on when the mains is supplied
Ultrasonic is OK, but you really need to full clean the bacteria and mould off very often
Heat-based ones just get scale like kettles, I prefer that, can clean every few months with some citric acid powder
For me, Ultrasonic ones are an issue with kid's bedrooms when the parents don't understand the cleaning requirements, especially if the humidity is needed because of a lung problem, personally I think heat-based vapour is more foolproof
I used to have silent swiss-made ones that were like a bowl of water that never reached boiling point, but there was some design flaw, so they refunded everyone and stopped making them - those would be my ideal solution
