I've already got an audio interface and DAW, but most of the time I can't be bothered to use it. I'm looking for an alternative option to simply record solo electric guitar sessions. I'd probably keep a mic on my amp, and would like to be able to simply press record on the recorder and let the tape roll.
Requirements are to have as good a sound quality as possible, simple to use, and the ability to easily transfer files to a PC for burning to CD etc.
I know they're different animals, but I'm thinking about either a Tascam DP-008EX multi-track or a Sony handheld 2-track recorder, such as the PCM-D100.
I think the Tascam might be really fiddly when transferring tracks to a PC (it seems to require a couple of stages which are carried out in realtime).
The Sony probably has better audio quality, but is obviously only a stereo recorder with no effects (not a significant drawback), and I'd need some sort of adaptor or preamp to convert a mic with XLR to its input.
I just wondered if anyone had experience of these, or could recommend any other interesting non-DAW based solutions.
Thanks!
Of course, there are larger devices with more tracks and some onboard effects. I will leave those for others with experience to tell you how practical they are.
Got an iPhone or an Android phone? If I was in your shoes I'd just spend £33 on an IK iRig Pre (Andertons price), leave it connected to the XLR cable all the time and use the phone to record stuff when the lightning struck. If you don't have a favourite "press one button to start recording" app already, then IK has a free app you can download from Apple or Google. I've not used the IK app myself. I'm using Voice Memos on my iPhone (they're dropping Music Memos, sadly), but at least it can record at high quality and store into lossless audio files.
So, turn on the amp, attach the phone to your IK Pre, load the app and press the red button whenever you want to. Easy! :-)
If I've got an idea, I'll try and get it captured using the iPhone and Voice Memos - using the internal mics. I've also got an old M-Audio handheld recorder, but it's something else to keep charged up and carry around, so I don't. It's also harder to transfer the file to a computer from there, too. With the iPhone, I just use Airdrop to my Mac. I've used Multitrack DAW and Garageband for field recordings on my phone and they both work well. Multitrack DAW is rather good on the limited screen real estate of an iPhone.
If I want something that sounds a bit better, and if I have it with me, then I'll pop my Shure MV88 mic onto the phone and use that. That's also good for high volume recordings at band practices, where the internal mics/AD convertor on the phone would just distort and give you a brick walled recording.
I don't have a mic sitting permanently in front of my amp (although I'm musing on that now, sounds like a nice idea...) but I'd just plug my phone into an iRig Pre if I did. They're cheap, easily portable and just work.
Two Mic's,two XLR's. 4-track recording. Can overdub tracks 3 and 4 while listening to 1 and 2.
I use mine all the time. The value of "I'll just turn on and hit "record"" cannot be under estimated.
Rather than,"I'll just hit record after turning on PC, firing up Daw. Loading a template,.."
Feedback
