If I'm not broke by the time these are actually available to buy, I may give one a whirl. I was initially put off by the digital reverb but I usually add a Flint to the front of my "pure analogue" tweed Champ anyway so it doesn't make much sense to rule out the new Vibro on that basis. However, at £799 it is expensive IMO for a PCB mass production amp (roughly the same price as the arguably more useful ToneMaster Deluxe) so I may end up ruling it out on that basis.
It's good that they've given it a proper speaker jack, rather than the phono on the originals... but bad that they've made it 3.2-ohm - although it can also safely take 4, contrary to what they say. Given that it's not intended to be a reissue it would have been far more sensible to make the speaker 8-ohm instead, then it could have used a much wider variety of external cabs.
They could have picked a much better speaker than the remarkably average-sounding Ten 30 as well, although that seems to be standard for this series...
But I'm pretty sure it would have sounded a lot better if they'd used an 8-ohm *decent speaker*...
Preamp valves are arguably better mounted on the PCB as it keeps the lead dress to them totally consistent.
Not including the footswitch is *very* cheeky at that price though.
The Vibrochamp is for recording precisely because it doesn't have any low-mid flab.
I would prefer a Vibro-Champ with a decent 8, I think. I do like the original Super Champs with a 10', but they're actually based on a Princeton Reverb circuit anyway.
