I fancy having a go at building my own amp, preferably a head. I’ve seen and heard good things about Vyse, Modulus & Amp Builder on here.
Just looking for any recommendations, pitfalls, lessons learned etc. Which one are epic and which ones are a bit meh.
I looking to go with something less than 20 watts and I am open to any type of amp really.
I’m proficient at wiring, soldering, understanding circuits etc as I am an electrical engineer by trade although not for the last 15 years.
Something that could be modified my be-handy for future messing.
Thanks
I canno
To my knowledge no one does an AB763 kit but Ceriatone will give you at least 10 different Dumble clone options, plus a load of tweed Fenders, Matchless Trainwreck and Hiwatt.
Modulus seem to have the Marshall circuits covered.
Personally I'd recommend Ceriatone as I've built three of them and they are all excellent, but I started with an Ampmaker SE5 as the instructions were excellent but I was a lot greener than you when I started.
Posting this as a member, not a supplier
First amp I ever built was a heavily modified tweed deluxe, I read a book and did all the suggested mods straight away and the worked fine, but compared to a real tweed deluxe was completely meh! I didn't build another amp for 5 years or so as a result. I now always tell guys to build amps stock and then modify from there.
My second amp build was a 18w 1974 type amp, the first time I got to crank that thing was glorious, it changed my understanding of the guitar // amp relationship and put my large pedal board in danger. It also led me towards Trainwreck amps and variations of them for a good number of years.
It was a few years after the 18w that I built a tweed deluxe properly, did one simple mod to it to trim the bass and it still sounds great, currently with my brother in SA, it is simple and there are lots of things you can do to it to tweak it if you want to. I just modded one of mine to have a blackface TMB tone stack and master volume and it is lovely.
The other sub 20w amp that for clean tone is stunning is a blackface Princeton reverb, there is much more involved in building one and I would not really consider it to be a beginner project, but you say you have some relevant experience so you might be able to handle it.
The suppliers you are looking at all offer slightly different things but as far as I know all offer good product, so it is really about you building an amp that you are going to love, rather than just have success at.
What I had meant to finish with was :
I cannot recommend Modulus highly enough. Michael has shown a phenomenal amount of patience and knowledge with me as I piled question upon question (I'm certain repeating my questions more than once).
My only word of caution would be that amp building feels like it might become an addiction!
Good luck
I'll also second Michael's knowledge and willingness to help
I absolutely would not recommend a Princeton Reverb as a first time build. In fact any amplfiier with onboard effects is a bad idea for those with little-to-no diagnostic ability.
Great starter projects:
- 5F1 Champ
- 5E3 Deluxe
- 18w Marshall
Good luck!Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
The Princeton Reverb is a phenomenal amp. However, I have just converted a modern PR to (near-)blackface spec, and it was easily the most complicated valve amp project I have undertaken to date. It worked first time, but I have already had to tweak the tremolo depth and may still want to tweak the speed range.
I would certainly recommend a 5E3 build. Modulus do two head versions. Build it, play it, then decide whether you want to mod it.
I'm seriously considering my first build project and eyeing up something from @Modulus_Amps at the moment.
I met up with @Kalimna at the guitarshow with two of his recent builds to have a look over.
Was looking at figures a few weeks ago, last year we shipped ~150 amp kits and also started selling kits in the US market for the first time, probably a result of the transformer issues they have there.
Ultimately, I'd love to build a Princeton Reverb but I understand that's going to be too ambitious as a first (or probably second) build.
I've got a Marshall shaped hole in my amp collection, so looking at your 18w or the 20w Plexi-ish amps. The extra headroom of the 20w and your demo make it look ideal and a reasonable place to start.
I'm intrigued by your comments above about Trainwreck amps. From what I had read about him, he sounds like some sort of Happy Gilmore type amp maverick who cannot be emulated. Your experience building one of his designs sounds like a huge success?
I've build several pedals and partscasters now, and rewired most of my guitars. I consider my soldering to be an acceptable level..
There is more space in the chassis to work with so is actually easier than some of the tweed builds that get tight fast.
