Bugera PS1: Can it be used as a dummy load with no cab???
Hey guys
I need a really cheap ‘dummy load only’
Can the Bugera PS1 be used as a dummy load with no cab attached? Online description is unclear. Some people saying yes and some say no
Many thanks
  • StevepageStevepage Frets: 3055
    I have the Harley Benton PA-100 which I use with a Triple Rectifier. I used it just as a dummy load and had no issues.
    I read that about the HB but there’s none available for months but it’s not 100A% clear if the Bugera can do the same
  • ICBMICBM Frets: 72471
    Yes, any attenuator can be if you turn it down to the minimum output setting.
    I would be wary about the 100W rating though - if that's 100W of electrical power rather than a 100W amp, it's not really suitable for anything above a 50-60W amp when used as a load.
    Awesome I’ll grab one then :)It’s for a 50 watt power amp so should be ok then
  • John_AJohn_A Frets: 3775
    Id still be wary about running the amp on full for an extended period
    Will be ok as the amp will be on zero volume. I’ve  got a stereo power amp but I’m only using one channel now so just need a cheap dummy load to keep it happy
    That'll be fine then :)
    If it's definitely going to be on zero volume, you don't even need a load - just get a spare jack plug and connect the tip to the sleeve, so it shorts the output. Completely safe for the amp when there's no signal - in fact some valve amps (eg most Fenders) have switches in the speaker jacks to do exactly that.
