So I'll see if I can get it plugged into android. If not, it might be a pc only thing.
Collision rock band
I've used mine to connect several USB-connected audio interfaces, USB thumb drives, a Headrush Gigboard (to back it up). The only thing it won't let me do is use a USB hard disk drive - because the iOS device can't supply enough power to start it spinning.
Might be worth a try?
Not official, no, but it does claim to do the same job. The ipad knows something is there, but doesn't know what it is. Maybe I'll try it if I can get into a store and try before I buy.
I might just get one of those irig type things and hook it up via that, but it's not essential...
You need to be careful with non genuine Apple cables and convertors. Inside every genuine lighting port adapter is a little chip which negotiates with a chip on the phone / iPad, motherboard and identifies it's self and voltage regulation is handed over if all is well. This chip is sold pre configured on the end slice of a lighting port connector to people who want to build approved accessories for a few dollars. To avoid paying this fee to Apple the manufacturers of the cheap non approved accessories put it a chip with enough code to be falsely recognised and (sometimes) work but that critical safety feature is left out . Meaning a £10 accessory can kill an £800 phone.
I'm really tight myself but never use non genuine Apple stuff because I know how the system works and why certain things have to be there. It's annoying they mark it up so much though for sure.
Maybe I'll give it a go.
Tbh though, apple can suck it for being completely non-standard and incompatible with everything. I don't know why consumers put up with it. Maybe I'll find one second hand.
