Can anyone help me source the correct pickup surround so I can replace the Blacktops in my Gretsch 5420 with Mojotrons?
The surround for the Blacktops has three screws which the pickup lugs attach to and are adjusted. The surrounds are attached to the body with four screws. The pickups can be adjusted vertically through the surround to move the pickup closer to the strings.
The Mojotrons don't have lugs, and have two screws to connect to the surround. I'm not sure the Mojotrons can sit surface on top of a surround and clear below the strings?
Thanks in advance, I'm struggling!
One way people do it is add a small wood bar under the pickup (lolly sticks..) which is fixed in place by the pickup's two through-screws.
The bezel screw at the single screw end is threaded through the stick/bar, so it still acts as a height adjuster.
The other end with the paired screws, add the TVJ adaptor to the stick. That takes a single screw to the paired BT setup -
https://tvjones.com/dual-screw-mount-adaptor
(Making one of those wouldn't be too hard, to save the post wait).
Have a look at post #19 in this thread for a pic it should be clear what the deal is.
An alternative is adding wood to the guitar, inside the body at the pickup rout ends, so the through-mount screws have a place to go into.
And replace the BT surrounds with trad surrounds - but check these are the same size/screw positions. The old model 5420s weren't but yours do look like more like the trad surround sizes.
A bit of ply below the pickup sounds like a plan, with new surrounds.
Bandcamp
Spotify, Apple et al
