Simply put, you keep the core signal unprocessed and remix with repeats at the end.
Some pedals (Cornish TES) do this internally with no need for something like a wetbox to remix.
And if you split the signal via a parallel send and return loop, the affected signal on when it returns will need some sort of level/mix control.
The benefit of mixing is you keep the core signal away from digitization
Even a boss dd-2 works like this I think - completely untouched signal + the repeats. @ICBM?
I'm guessing no, because you'd need to somehow separate the original signal from the repeats, and then "duck" the original.
EDIT: Hmmm, maybe you understood exactly what Kill Dry is, but don't understand what people are writing in the thread. Apologies if I misunderstood.
Here's a list a few pals of mine created in 2012- you can add a fair few to it.
Boss DD-2 (with dummy plug)
Boss DD-3
TC Electronics Nova Delay
Boss DD20 giga Delay
MXR Delay system II
TC D-two
Line 6 Echo Park
Line 6 DL4
Empress Super Delay
Diamond Memory Lane
Eventide Timefactor
Yamaha UD stomp
Skreddy Echo
TC 2290
Skrydstrup DDL Custom Delay
Providence Delay 80 (with dummy plug)
EHX Deluxe Memory Man
Ibanez DE7
TC Nova Repeater
Providence Ch
I've got no experience of stereo set-ups.
