I was using my Boss RC3 earlier today. When I stomped on it to start the loop, it showed an 'FL' error code on the screen.
I could not clear this code, so I switched it off. When I switched it back on, it flashed 'Er' on the screen.
I have tried a factory reset, but was unable to complete the process- it just showed another error code, 'dN'.
The manual suggests that this means the unit needs to be returned for repair. However, I've had similar issues in the past and have been able to restore the pedal eventually. It's been running trouble free for quite a while but I can't seem to clear the error this time.
Has anyone experienced similar issues?
Worth a try, but no luck unfortunately. I'm looking for a Boss approved repairer now :-(
Failing that, I have one I’m not really using that I might sell...
I suspect the memory has failed. Not sure whether it is an economic repair or not. It has happened a couple of times before and some messing about with factory resets etc has worked. But not this time.
For about 3 minutes. Then it crapped out again :-(
Back to Roland/Boss I go.
