Will I destroy my amp?
ETJCETJC Frets: 25
edited April 2021 in Amps
I know these questions are boring but will a Marshall MG 100hdfx (4ohm) damage my 10 watt (8ohm) Blackstar 10 AE combo speaker if I play very politely? (It's the 100 watts I'm worried about, assume impedance will be ok)
Or does somebody want to sell me a cheap cab?
Thank you.
  • ecc83ecc83 Frets: 1633
    The Blackstar uses the 70/80 Celestion rated at 80W. Now, if you were to blow the bllx off that Marshall then yes, I dare say you would wreck it and if it burned out at full chat possibly damage the amp but. Cellies are tough and you would have to be making a g;awful row to put either speaker or amp in danger.
    ICBM will no doubt give us his expert view? (I don't know the amp) Be warned though? I don't think he likes the 70/80 a lot!
    I shall almost certainly be donating some speakers and a couple of rough ass cabs to deserving causes around late summer. First comers collect.
    Dave.
  • ICBMICBM Frets: 72361
    It's safe. The Blackstar speaker is rated for 80W, and the Marshall won't actually deliver quite 80W even into 8 ohms - the full 100W is only into 4 ohms, it's typically about 70W into 8 ohms - and I think the Blackstar speaker is actually 16 ohm, which limits the Marshall to about 35-40W max.
    That is true :).
    But I still don't like blowing speakers. Not even Rocket 50s ;).
  • ETJCETJC Frets: 25
    Great. Thanks a lot both of you,
    Ed
