+1 I find there is always a small engineering firm who can do this sort of thing on an Ind Estate nearby.
If you are starting from scratch go for aluminium IMO. More expensive than steel and you need a heavier gauge but MUCH nicer to work with.
Dave.
Try Modulus Amplification, I know they do the cut-outs themselves, and should be able to add extra pre-amp valve holes to a standard chassis
:-O
You could try Ceriatone. The new King Kong has 5 noval socket holes and 4 octal holes. Its a monster. I'm sure you would be able to find room for another socket hole and cut it yourself.
Wow! Just a suggestion!
Dave.
