Football is rubbish.
I don't recall ever seeing it written the 2nd way.
What has always puzzled me about the open Am - or the open A come to that, is why the bottom E string is always shown muted.
PS. We Australians do cricket scores the proper way round, and don't you forget it!
Also, I have seen chord charts, and no doubt there are vids, that teach the "easy" way to play first position chords which have the B major played with an F sharp bass - to avoid barring at the second fret.
Me! Especially with an A chord. The second inversion is unstable and generally sounds pretty bad. I'd only ever use it usually if I was playing a chord sequence over a pedal note and otherwise would take a lot of care to avoid it unless it was very much in passing.
22444x (B, 2nd inv)
476454 (E, 1st inv)
56444x (B7, 3rd inv)
77999x (E, 2nd inv)
9 12 11 9 10 9 (A, 1st inv)
11 14 13 11 12 11 (B, 1st inv)
12 14 14 13 12 12 (E, root)
I've always been confused about why a C/G chord (332010) sounds sweet to my ears but a C/E chord (032010) doesn't. Sounds like the former is a second inversion and the latter is a first inversion. Are second inversions inherently more stable?
However I do always mute the E string when I play an open A because that doesn't sound so good. So why does C/G sound better than A/E?
