Ampeg PF800, PF115HE and PF410HLF Bass rig £550
Ampeg 800w bass rig for sale in excellent, rarely used condition
(as you would see if I could actually upload a pic of it).
Ampeg PF-800 Amplifier
RMS power output: 800W @ 4 ohms
Preamp: MOSFET
Power amp: Class D
Tone controls: Bass, mid, treble
Mid-tone control: 5-position
Ultra Hi/Lo boosts
Onboard compressor
Balanced direct out (Pre/post EQ option, -40 dB pad, Ground lift)
FX loop with dedicated mix control (foot switchable)
Power amp in/preamp out
1/8” headphone out / line in
-15 dB input pad
Mute (foot switchable)
Power supply: switching
Dimensions (H x W x D): 3 x 15 x 11 in, 80 x 381 x 272 mm
Handling weight: 11.8 lbs / 5.35 k
Ampeg PF-115HE 450w Bass Cab with 3 position horn
Vintage Portaflex flip-top cabinet design
Black diamond tolex
Vintage B-15 grille cloth
Rugged 15mm poplar ply enclosure
450W RMS power handling @ 8 ohms
1 x 15˝ ceramic Eminence LF driver
1˝ HF compression driver w/L-Pad level control
Frequency response: 50 Hz - 17 kHz
Sensitivity: 99.5 dB SPL @ 1w/1m
H x W x 23 x 21 x 14 in / 584 x 533 x 363 mm
Handling weight: 45 lbs / 20.4 kg
Removable Casters
Ampeg PF-410HLF 4x10 Bass Cab with 3 position horn
Vintage Portaflex cabinet design:
Black diamond tolex
Frequency Response (+/- 3 dB): 55 Hz - 17 kHz
Usable Low Frequency: 30 Hz
Impedance: 8 Ohms
Power Rating: 800W rms, 1600W peak
Sensitivity: 101.0 dB SPL 1w/1m
Maximum SPL: 130.0 dB
Cabinet Construction: Poplar Plywood
Speaker Specs: 4 x 10" Eminence Speakers, 1 x HF horn with 3-position switch
Inputs/Outputs: Dual 1/4" Parallel Jacks
Dimensions:
H X W x D 27 x 23 x 17in / 598 x 578 x 445mm
Weight 73.4 lb (33.3 kg)
Removable Casters
Collection from Leatherhead, Surrey (J9, M25)
With so many comparison web sites out there, how do I choose the best one?
