This is not a fancy guitar - I just want to be able to tune it and strum it really.
EDIT not my favourite strings but they fit nicely on the cheap but OK sounding scale!
I remember when I was learning and progressing steel electric strings were put on my (Encore?) nylon guitar! That was traded in for an electric and I think they whipped the strings off quite quickly.
Nylon strings often have silver-plated wound strings which might explain some of the cost, although there are definitely cheap ones which don't.
I will try the ones linked above and see how i get on.
I did wonder why my google search brought up lots of D strings... now I know!
The D'Addario EJ27n's mentioned by drofluf are also OK if you are on a budget. I've only tried the 3/4 equivalent.
Thanks
I am yet to do the stringing as I need to concentrate on getting it right. Think the last time I put strings on a guitar like this will have been 30 years ago!
It can be a bit daunting at first but it is actually quite easy. I can now almost do it in my sleep! The correct tying around the tuning machine barrel is important for stability.
The strings will need frequent retuning as they bed in and stretch, particularly initially. Good luck.
You can trim the excess off after they're bedded in and you know they won't slip further.
lol . Too true!
