FS/FT - Epiphone 56 RI wiring harness, switch & p90s
Fifty9Fifty9 Frets: 492
edited May 2021 in Parts £
Taken straight from a Korean Epi 56 RI goldtop Les Paul but have kept the cream soapbar covers so these come with black ones.
A nice usable taper on the alpha pots and a full size switchcraft switch. I’m no expert but it looks to have treble bleeds on too (correct me if I’m wrong). One of the pots is starting to go a tiny bit crackly & I have a spare 500k alpha pot that I’m happy to include for when it needs replacing. It’s only a small amount of crackle & id not bother personally as it’s perfectly usable as is - plus am sure some deoxit will probably sort it - so any replacement shouldn’t need doing for a good while yet.
£50 + postage seems about right I think as the pups are nice. Let me know if I’m way out and I’ll of course listen to offers.
Trade wise I’m actually after a push pull harness for a Les Paul, including switchcraft switch. Perhaps a Jimmy Page harness if one’s going unused.
https://imgur.com/gallery/wxlZP8Q
  • FunkfingersFunkfingers Frets: 14584
    Fifty9 said:
    a push pull harness for a Les Paul, including switchcraft switch. Perhaps, a Jimmy Page harness if one’s going unused.
    FYI, the so-called Jimmy Page 4-pot wiring harness is designed to operate with a pair of dual (side-by-side) coil pickups.
    It is not appropriate for P90 pickups (including stacked coil lookalikes).
    IMO, this wiring harness is wasted on Firebird or mini-humbuckers. There will not be sufficient sonic variation and the "inside" coils are too far apart.
    Might be worth trying with 4-con Filter'Trons.
    If I knew what replacement pickups will be going into the Epiphone LP, it might be possible to suggest a circuit to get the most out of them.
  • Fifty9Fifty9 Frets: 492
    edited May 2021
    Thanks mate.
    I have 4 conductor pups that I’m fitting to a hb les paul - hence my interest in a Jimmy page harness in exchange for this. I’ve already changed out the pups & harness in my 56 copy.
    Paging (see what I did there?) @sixstringsupplies ;
  • sixstringsuppliessixstringsupplies Frets: 429
    thanks @Funkfingers ;
    @Fifty9 depending on your budget we have a solderless Page harness launching next weekend - see details here:
    https://www.thefretboard.co.uk/discussion/comment/2943602
    For Modders, Makers, Players
    https://sixstringsupplies.co.uk/
    Our YouTube Channel for handy "How-To" Wiring Tutorials
