Cable OCD overcame me.
Seeing as everything was labelled  seeing as I was rewiring after the house move, and seeing as there's no major pieces of kit on the horizon...
And now I've run outta zip ties.
  • goldtopgoldtop Frets: 6154
    I did that once. And - inevitably - within a month had swapped things around and unpicked everything.
    I've got to do something similar (but with less commitment) when i rebuild my little amp wall after the studio/workshop revamp. I'm not looking forward to it.
    (I'm overlooking the fact that the amps' front panels are facing the wall. Surely you've got that covered? ;))
  • tekbowtekbow Frets: 1699
    edited July 2021
    (I'm overlooking the fact that the amps' front panels are facing the wall. Surely you've got that covered? )
    Yup, I've left plenty of slack on the free ends so I can unplug everything and remove the gear, then swing the shelves back around to the below orientation before reinserting.
    Then I start on the desk end.
