A modern guitar without a truss rod?
TrentGuitarsTrentGuitars Frets: 1731
edited July 2021 in Making & Modding tFB Trader
So I had this recommened  to me on youtube so thought i'd give it a watch
He has excellent craftsmanship and I do see what he's trying to acheive with the couple mechanism and that but I'm not sure I could get behind a guitar without a truss rod in this day and age?
Essentially he's using an incredibly rigid D tube carbon fibre rod which takes a rather large chunk out of the neck blank. Basically, he's stating that this D tube will give you a totally flat neck and he's relying solely on string tension to give relief. Surely this is a risky prospect? being able to dial in the perfect amount of neck relief is such a core part of any guitar setup, how will he be able to make it playable with a range of string gauges and tunings?
I might be mistaken but I am not a fan of the idea! Thoughts?
  • ICBMICBM Frets: 72390
    edited July 2021
    Vigier have been doing that for decades, although with solid strips instead of a tube. It seems to work perfectly.
  • TrentGuitarsTrentGuitars Frets: 1731
    Interesting, across all gauges and tunings and action choices?
  • moremore Frets: 230
    edited July 2021
    Originally, guitars did not use truss rods, until steel strings arrived. The first ones used strong stiff woods like  Ebony. Later,nonajustable  metal box rods were inserted into the neck. All Martin had this kind of rod until  1985. There are a number of different adjustable truss rods available.  I could not get your youtube link to work, But I don't see it would be a problem to do things differently.
  • DrBobDrBob Frets: 3006
    Doesn’t Rick Kelly at Carmine St guitars build Teles/Esquires without truss rods, I think he said that having the Truss rod under the D&G strings makes them sound “different” .. Don’t know if I fancy having nothing at all in there
    My concern isn’t whether the guitar neck will be stable, more that the relief isn’t adjustable for different styles of playing
  • Winny_PoohWinny_Pooh Frets: 7771
    edited July 2021
    If the neck never moves regardless of string gauge you can build in relief when doing the fret levelling.
    Interesting, fair point indeed!
    It should be. There's actually far less variation in the 'correct' relief than you might think, and you generally need slightly more with heavier strings so it should work out right as long as there is *some* even with the lightest strings.
    It's a bit like nut height - a lot of people think it's a 'player preference', but in practice - as long as you're not a complete gorilla - the same height of just microscopically higher than the first fret is correct for all styles and string gauges.
    That would be tricky, since the normal way of doing that is to set a deliberate back-bow using the truss rod and then level the frets...
    You would have to do it with external clamping, although that should be possible.
  • FelineGuitarsFelineGuitars Frets: 11594
    edited July 2021 tFB Trader
    The two i have seen first-hand had truss rods, not that they did much as the necks were so huge
    I see what you’re saying, the idea being that it can set it’s own relief simply through the side affect of more tension from heavier gauges.
    I have just found in the past when the neck is too flat you get the buzzing that’s easy to remove with a hair of adjustment on the truss rod. But like you say this system is operating on a different set of variables.
    the carbon fibre is epoxied into the neck, too.
  • BlueingreenBlueingreen Frets: 2597
    Interesting that you should say that.  When I buy a new guitar almost invariably one of the the first things I do is take out some of the relief.  The guitar tech I go to most often has similar preferences to me (and knows I'm a fussy bugger) so when he's set a guitar up it's usually perfect, but almost everyone else seems to set a guitar up with more relief than I like.
    Not sure the explanation.  Maybe I just like an abnormally flat relief.  My other thought is that perhaps people setting up guitars fear fret buzz more than they fear a sub-optimal relief setting and and err on the side of caution.
  • WezVWezV Frets: 16691
    I've done quite a few necks with CF bars and often with laminated construction too.
    It's possible for them to be so stiff the strings don't add any relief at all... so I'm always thankfully I included a truss rod to dial it in.
    These days, when I favour a more flexible neck, controlled with the truss rod... everything is under tension.  Its a more vintage flavour than a very stiff neck, which can sound very direct and modern.
    If I do use any CF reinforcement I now go for hollow rod, epoxied in.   It adds predictability and stability without making things too stiff.
  • JeremiahJeremiah Frets: 631
    Didn't Status use graphite necks with no truss rod on their basses at one point? Though I'm pretty sure they have truss rods now.
