Well it’s took me probably over a couple of weeks to get 55 seconds done so far ,out of about a 5minute 48 second piece . I had a few days I could not fit it in to my schedule so was dreading it today
but I managed to do about 16 notes in 30 to 40 minutes , best thing was , after I had done it , I thought oh I’ll see if I can figure out what it’s doing and I found out the lick was in box 5 of the blues scale and managed to transcribe it to boxes 5 ,4 and 3 in A minor before having a rest, now I’ve got a cool lick which I should use and remember more and adapt so I’m quite chuffed .
The thing that takes time up sometimes is getting the flow of the previous piece that leads into the current bit I’m learning / figuring out I probably was longer than 30 -40 minutes but counted 30 as that’s when I seriously started .
its quite tricky for beginners as even in relatively small box areas there are a few combinations ,and if you’re a bit cloth eared you can take a wrong road before you get it sounding right (hopefully) lol
I usually allow 20 to 40 minutes , sometimes you feel like you could go on and on while others you’re pleased to stop ,it can be a bit of a strain on the brain
One thing I will say though, I am chronically bad at learning anything from TAB, but a long process of learning the notes without TAB ingrained it in my memory.
That would be ideal
