EMG bridge pickup hum
Playing with my Warmoth the neck EMG is pretty quiet in terms of ground hum. However, switching to the bridge pickup the hum/buzz is quite annoying and obviously louder.
Could it be a simple connector not on right? The EMG 57 is quite high output so I'd expect some noise when played with high gain but i feel it's a bit too much.
  • FunkfingersFunkfingers Frets: 14424
    Yes. That is the mostly likely explanation.
    Check them all.
    If your circuit involves the 157C Buss Board PCB, check any cables fastened by screw-down clamps to/from the selector switch.
