https://newtonestrings.com/do-not-cut-newtone-strings/
Luckily, on the standard posts on almost all acoustic guitars, it isn't an issue if you fit the strings correctly - whichever of the two alternative best methods you - since you always put the string through the post, bend it, wind on and tune up before you cut off the loose end. If you don't you're doing it wrong anyway!
The real problem is with Fender-style split-post/hole down the middle tuners, which a very few acoustics have too. (And Floyd Rose bridges, I don't think you can use Newtones with those.)
So not one of these
...and if you do, then they stay the same for months and months.
