I'll have a play with my lot over the weekend, and see what comes closest to the Mk1 Guvnor.
If you have room on your board (and the - or room for - appropriate power supply) the Blackstar HT dual is pretty similar sounding.
What settings roughly are you using?
I'm guessing clones of the drivemaster will be rarer, but I could be wrong.
Man the internet's making us lazy, isn't it? If you'd told me when I was 10 that I could look up any question I wanted and just had to type in to a computer in my house, I'd have thought it was the greatest thing ever. )
One of the things I would like is clones of them on smaller mxr/nano sized enclosures for international gigs when flying.
The Guv'nor and Drivemaster circuits are identical apart from some component values - and it's a "distortion" circuit in that the clipping diodes (which are LEDs) are to ground rather than in a feedback loop. But so are some other well-known "overdrive" circuits.
The Shredmaster is substantially different though.
Without too much messing around, and back-to-back, I've been getting pretty similar sounds to a Mk1 Guv from
Blackstar HT-dual, Marshall Jackhammer and a Zvex Distortron.
Admittedly, I haven't had *exactly* the same sound, but I haven't played with them too much, just going for a similar sounds to the Mk1. A little longer and I'm sure I'd get *exactly* the same sound.
Essentially the first part of it is like the Guv'nor/Drivemaster (but with other different component values, different 'harder' clipping diodes, and a fixed middle control), then it has a second IC which is an extra tone stage which operates the contour control, and an output buffer.
