Been using a couple of Behringer 205d's for vocal monitors for gigs for years.
At a gig on Saturday one of them just started flashing orange light and no sound came out of it. We run from Aux out 1&2 on the desk into a dual 15 band EQ rack system and then out to the monitors themselves.
I plugged it all in yesterday and ran an mp3 player through the desk at various volumes for about 2 hours and both worked perfectly.
Anyone have any ideas what could have caused this? I'm assuming it might be borked and as they've lasted a good few years won't be the end of the world although I could do without buying a new one tbh
I had a feeling it might be something like that. Will try it next gig and see what happens.
cheers for the response.
If it was then that can be a problem as it normally means the SMPS (power supply) turns on, see's an abnormal load (bad capacitor) so turns off then turns on, see's abnormal load (bad capacitor) so turns off etc etc and so on and so on.
When a SMPS does this you will often find at times it will start up, the cap will polarize and stop leaking, other times from cold it won't . This is because the mains isn't a constant voltage, it goes from nothing to a peak voltage and then under nothing to a peak voltage. So the exact point of turning on makes a difference, not that you could time it being it's 50 times a second
If it is an overload fault then remove signal input, turn off unit and turn back on and all should be well but if it plays up with no signal applied then my money is on the above explanation
If the problem persists then start by looking for that, unfortunately they can go bad and show no visual signs at all in some case (some vent from the bottom) but it gives you a start at least
