try it and see is the best advice
I used to run my Helix into the FX return of the amps in the studio at rehearsals, just using the inbuilt amp blocks and they honestly sounded extremely good through a real guitar cab. I use the SD Powerstage 170 - plenty loud and good EQ.
It would also mean you don't have to worry about faffing around with IR's for each preset, though I suspect you like that as an Axe FX user
@sjo89 the SD Powerstage 170 was the one that keeps coming up. Isn't there something you have to do in order to get the full power from the unit? Is it the ohmage?
For clarity, I do not own an FM3 but I'm hoping to get one pending the sale of this OR/ if traded
https://www.thefretboard.co.uk/discussion/214430/fs-ft-fender-65-deluxe-reverb-reissue-ft-fm3#latest
Yeh I cant remember exactly what it was, whether it was 170W at 4ohms or 8ohms. Either way I was running it into 16ohm 4x12 and, trust me, volume wasn't an issue.
Don't get the Behringer - shitty company. Slave labour (legit).
As to the SD 170, I believe it's 170W at 4 Ohms
Is the cab just for you really so you can have what feels like a guitar amp on stage?
If you were sending to FOH I'd want a PA speaker so that I can hear the tone the FOH hears. I've a Yamaha DXR10 which is excellent.
I wanted to dip my toe in the frfr pool so tried a friend’s Mackie PA cabs which sounded ok so bought a dxr10, which was better still. It did struggle a bit with a loud(ish) band and the tweeter is noticeable, giving a plasticky edge to the top end.
The power amp with my existing Mesa Mini Recto Cab also appeals but the Redsound sounds like the solution, especially as I also play bass and that system could cater for both guitar and bass.
Would one Redsound be loud enough and can it keep up with a full band, drummer etc?
I'm going to be selling my one soon, I upgraded to a stereo pair of Redsound MF10 which are also very good.
For my purposes, I play function stuff or the classic rock band I play with where it's (Eagles, Doobies, Steely Dan, Toto etc) - I am lucky that our drummer plays a top of the range Roland kit and so volume is controlled but it's good to know it would be ok
Cheers
One Redsound will be more than adequate. Ive rehearsed and played live many times with a LG12.
